Having problems with dxl files in Lotus Notes
Dealing out with dxl files generated by Recovery for Lotus Notes do not reconstruct the database and/or supplied whichever inaccuracy notifications. May I know someone expert in handling such problem like this?
Answered By 15 points N/A #105579
You can review or modify documents that you have created using DXL (Domino XML), and the agents that used to perform that action will be using the NotesDXLExporter and NotesDXLImporter classes. Some of the things that you will need to note are as follows:
With the first agent,  "NotesDocumetExporter" will use it in the creation of the XML file which will be in the folder location, C:temp.
That file will have the selected document which will be in the XML format, and the document can be viewed using a text editor, Microsoft Internet Explorer or any other XML viewer and editors that you are using on your computer.
One thing that you should be careful not to do is changing the file structure of the document. For the second agents, "NotesImporter" will be used in the replacement of the document in the database.
Clair Charles
