I’m not sure if that version you installed is really compatible with your video card because the only version I found to be compatible with 32-bit Windows 7 for NVIDIA GeForce FX 5200 is version 6.06 released on April 9, 2010. Since your screen turned black after installing the latest version then it only means there’s a problem with the update.
It may also indicate that the version you installed is not compatible with NVIDIA GeForce FX 5200 video card. To fix the problem, download NVIDIA 6.06. It supports Windows XP, Windows Vista, and Windows 7 both 32-bit and 64-bit. This NVIDIA driver package includes support for NVIDIA GTX 470 and NVIDIA GTX 480. This driver package includes the following enhancements:
Enables GeForce GPU overclocking
Enables GeForce GPU temperature monitoring
Enables system tuning and profiles for timings, clocks, voltages, and fans
Enables system monitoring for clocks, timings, fans, and voltages
Added support for ESA or Enthusiast System Architecture components
RICH Miner officially launches a new mobile cloud mining application, subverting the traditional mining model! No need to buy mining machines, no technical experience required, just a mobile phone, global users can start the...
I’m not a tech geek. I don’t keep up with every new gadget launch. I fly a few times a year, watch many movies on my phone, and live in a small apartment where...
With 2025 just around the corner, it is time to start thinking about what tech trends will be coming our way. Tech moves at a rapid pace. Some things may pop up next year...
1....
