Having problems with translating from English to Netherlands using Magento
Hi guys,
I'm using Magento, and I'm currently facing some problems with translation.
The default language is English, and I want to change the scope to Netherlands.
The Bing translate button is grey, and it says translate "Engels to Netherlands".
When I neglect the gray, I get an error message saying "error = true" (check screenshot).
How can I resolve this problem?
Thanks in advance.
Answered By 40 points N/A #94986
Hi there ,
It seems you are having problem translating English , Why using any other  third party software's when you have the incredible online translation service from the very own most trusted and most famous internet company Google .
I been using many third party translators to convert English to my native language but better than all that i found its pretty easy and convenient to use Google translator , its free too . and you don't have to install anything on your PC at all .
Just give it a try . the URL is :- https://translate.google.com/
It also has a feature of automatically detection of the language in which you are typing , impressive ha .
Give it a try and then if you like it remove all third party software's and switch to internet based utilities , next generation 🙂
