Having RJ-45 Cable Signal Problems till I reboot
Since I was having problems with RJ-45 Cable, I chose a different one to use, but the problems sustained. I can see a signal of yellow triangle consisting a black exclamatory sign in the taskbar as I plug it into my WildBlue modem and Lan input of my PC. I can find the red X symbol as always, on unplugging the cable from any one side. Although I have all the latest drivers of LAN for the board, a strange thing happens which is; the problem does not prolong as I reboot the PC. I got to see that black exclamation mark with a yellow triangle around it several times, yet I was connected to the internet few times though I wasn’t in most of the times. I am using Windows7 Home Premium. Please give me some ideas regarding this problem. Your precious ideas are highly valued to me. Thank you.
