I'm having so many bugs in my dns event viewer. I've encoded the error below. Kindly provide me an answer if this error happened then my all customers cannot ping server and server cannot ping Customers Systems.
Most of the clipping resources are not functioning.
Having so many bugs in my dns event viewer
There are several errors you may get with DNS issues, and each error has their resolutions. Unfortunately, we are unable to get the exact error messages you are getting when using the event viewer. Nevertheless, there are ways for you to get the exact solution you need to have those issues resolved. One way is visiting: https://www.microsoft.com/en-US/download/details.aspx?id=53314
The above link/website has the lists of possible error messages you might be getting and each has its own tip to have those issues resolved. Aside from the link above, you may also want to try: https://social.technet.microsoft.com/search/en-us?query=event%20viewer&query=event%20viewer
The second site will help you on some “How To” for event viewer issues as well.
Problem you are facing due to firewall setting.First of all please disable your firewall and look into if it is working.And it is necessary for both server and client computer.Firewall is the main cause I have to say.Then try setting your server configuration this way: Hold down Windows key and soon after press R. Then open a command prompt typing CMD.Then type command NBTSTAT -n and IPCONFIG /ALL respectively.
Then you have to right click on command window.Please mark select all and press enter on your keyboard.Finally it may be required to change DNS records.Also check if scope is activated on DHCP.
