Hi, I am going through some sort of problem with my Ricoh Aficio MP 6000, which is showing me an error message with error code SC 534. There was also a problem with my cooling fan. Do you think the problem is related to the cooling fan? I have previously asked for help in a forum but have not acquired any solution for this issue. Do you know anything about this issue and how to fix it? Your help would be very much appreciated.
Having some errors with my Ricoh Aficio MP 6000
Yes this problem was related to the cooling fan. It shows you 534 code, and it's about cooling fan. I don't know what is the problem with your cooling fan because you don't mention it. Ok, there are some problem that can give you 534 code. Try to check the problem one by one. Hope this can fix your problem.
B010/B188 SC 534 Right fusing pressure motor HP error 1 – HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 – IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 – Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 – motor drive bound
B132/B200 SC 534 Duplex exhaust fan error – Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error – check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error – replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error – replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error – Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error – Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error – Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error – Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error – Replace duplex fan
D023/D025 SC 534 Second duct fan error – replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error – replace the IOB
D027/D029 SC 534 Second duct fan error – check connections and harness to fan
D027/D029 SC 534 Second duct fan error – replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
