Having trouble with Cerberus (RAT) 1.03.5 beta
Hello everyone, I am used to have a perfectly RAT software on my desktop. Recently I have installed Cerberus (RAT) 1.03.5 beta in my laptop. The installation was successful. But when i try to use the software I get error. Please reply If there i any available solution. Thank you.
The application failed to initialize properly (0xc0000005). Click on OK to terminate the application.
Best Answer by Carl Jack
Answered By 10 points N/A #159056
Hello Bersh,
That error is most probably due to malware or virus infection on your computer, and therefore you will need to run a couple of antivirus programs as well as spyware detectors and see if they will remove the virus from your computer. Make that you reboot your PC after that.
The error could also be due to memory issues on your computer. The issues with memory can manifest because the memory is going bad, or it could be faulty. You should therefore try uninstalling the framework and then later on re-install it and see it works.
Hope that helps.
Carl
Answered By 0 points N/A #159057
That is a common issue when installing software on your computer. I think that you did not have followed their pre-requisites first before installing the original product; please check first the following notes before you run the application again.
1. Did you install any .net framework? If no, install it first then run the program again.
2. The program might probably be written in C# language, did you install C# redistributable package? Install it if you don't have one.
