Greg Lewis
40 points
Posted on - 11/25/2012
I've been searching the web for quite sometime now and still I'm having trouble on creating cue bin from cd mac. I am using Mac OS X and I want to create .cue/.bin file from cd. I heard that Toast is a great app for this. Can you give me a good link where to download it for free and how to use it in creating .bin/.cue files? Thank you
Having trouble on creating cue bin from cd Mac
I would suggest that you download Toast. It is verified to be spyware and virus free by Norton antivirus. This particular version is good since all of the bugs are fixed. It doesn’t crash like it used to be. If you have problems using this or have any questions regarding its capability, check this link http://wiki.williams.edu/display/docs/Using+Toast+to+make+a+CD+or+DVD
Try to drop and drag your files to the Toast and save it as disk Image. Then create an image file and name it as ext .bin and then create the corresponding .cue. Or other way of doing it is to go to Menu, and save the file under bin/cue
