Finlay
50 points
Posted on - 11/23/2012
I'm having a problem on how to rotate photos emailed. Each time I use my camera, there are some instances that some photos are landscape in style. Is there an easiest way on how to rotate them? Thank you.
Having trouble on how to rotate photos emailed
Dear Finaly,
You can rotate the photo while you are watching it, and after closing it return it to landscape again by opening it with Windows Photo Viewer and rotate it.
Or, you can permanently change its rotation using Paint on Windows 7.
1. Right click on the image and copy it.
2. Open Paint from the start menu, then 'accessories', then 'paint'.
3. Paste the image by clicking on the paste button in the upper left corner.
4. You will find 'rotate' in the same corner, rotate your image as you want.
5. Choose 'save as' and select JPEG and locate it, then click save.
6. Close Paint.
7. Open your image with Windows Photo Viewer, it will be permanently rotated as you made it.
There is a easy way to rotate the emailed photos. You did not need anything if you already have windows live photo viewer. You can either open the picture in the preview and you can rotate the picture even more simpler way, right click on the photo and it is in the menu to rotate clockwise or anti clockwise. I just did it for providing you a sure answer. If you like it have done your work with this solution simply thanks. Take care.
