Hello there,
I'm having trouble with creating my own theme with my HP laptop. I want my theme to be like the one in my mobile phone. I'm using MTC with Java Runtime Environment 1.6. MTC created an XML file but when I save the images, an SVG error comes out. Could someone please help me with the HP theme make your own?
Having trouble in Hp theme make your own procedure
MTC works very well with Java Runtime Environment 1.6 so the problem is not software compatibility. If your theme does not show any theme or if you get an SVG error, you are trying to download the images from a directory or a folder that has special characters. Change your directory to have Latin character. Do the same if your Windows username has special characters, change to Latin and reboot your System.
I hope this is helpful.
Can you please tell me which type of SVG error showing you? There could be two cases like “xml error message is shown”. If this message shown to you then your image is broken and you have to fix it.
The other case could be “the image does not have SVG name space”, you can fix it by adding “xml="http://www.w3.org/2000/svg" with the <svg> tag, for instance <svg xml="http: // www.w3.org/2000/svg">.
It’s means that you are using opera 8.01 browser which is without correct attribute name space considered as SVG. So, xml name space attributes are not present in SVG. It looks like “xml: svg”. This is supported by opera but you have to read about XML name spaces.
I hope this will help you.
Guidelines
1. Visit the HORSEPOWER website by typing http://www8.hp.com/us/en/home.html into your address bar at the top of your web browser.
2. Select "Laptops & Tablets" on the menu selections in the left area of the site.
Sponsored Inbound links
SSL Vouchers — Thawte
Select a total variety of vouchers using the most robust SSL
https://www.thawte.com/
3. Go with a starting model mobile computer, determined by your requirements, from the possibilities open.
Several
Select "Customize & Buy" on the menu selections from the left section.
4. Simply select the computer you desire.
5. Go with a processor chip.
6. Simply select the memory space you may need on your own HORSEPOWER mobile computer.
7. Go with a hard disk drive.
8. Select the optical push with regard to enjoying CD albums or DVDs.
9. Go with a WiFi minute card with regard to using the internet whilst away from home.
10. Decide on a battery from the possibilities open.
11. Opt for gadgets with regard to make use of using your HORSEPOWER notebook computer.
12. Select various productiveness software programs from being installed, determined by your requirements.
13. Opt for a security software program to safeguard your computer from viruses along with the worms.
14. Select "Review & Buy" and abide by your directions within the screen with regard to check out.
HP laptops have some problem with the software, so It’s often complain about theme creator. You can use theme creator pro software for making theme, that will support your platform also.
Find the software using Google or on File guru site.
