Having trouble with my music player
An error message appears: "Violation d'accés á l'adresse 0065FAFB dans le module 'GP5.exe)" after running the GP for 10 minutes. This usually happens after clicking on the button to play the music.
To fix this, I'd have to restart the application. If I don't restart, the  music could still be heard and would eventually prompt that there is insufficient memory and shut down on its own.
I am wondering what the problem is and what can I do to fix it.
Error:
Load error
Error loading E:/gpx/asdf.gp5!
Answered By 0 points N/A #118289
Hi there,
This particular problem revolves around Guitar Pro 5, the reason for the error is that when Guitar Pro 5 is executed the CPU is typically overused, this does not mean that Guitar Pro 5 requires a high power processor, far from it, a memory leak error that resides in the program is the main culprit, the only solution for Guitar Pro 5 is to save the file, exit the application, execute the application again and open the file previously saved again.
I would recommend to update to the most recent version of Guitar Pro 5, as that will surely rectify your problem.
