Having trouble while opening CSK hdf5 ScanSAR Wide mode L1A imagery
Hi all.
I am having trouble while trying to open CSK hdf5 ScanSAR Wide mode L1A imagery (https://sentinel.esa.int/web/sentinel/toolboxes) and I'm receiving the error attached below. I am able to open CSK hdf5 Strip Map L1A imagery successfully. So I need to know what is causing the error in opening this data. I would be grateful for any assistance about this issue.
The error says that this problem is linked with the metadata but the imagery can easily be viewed in other HDF viewers without facing a problem. I am unable to process it in these other viewers.
Error:
NEST DAT – Error     Â
An exception occurred:Â Â Â Â Â Â
Type: java.lang.IllegalArgumentException     Â
Message: data array size does not match 'gridWidth' x 'gridHeight'
