HD video on Nokia Lumia 900
Can't play video in HQ on my Lumia 900. Are any settings to look for? Played before. Or something in the video format?
It depends on the format of the video. Usually Nokia Lumia 900 can’t play certain video file format. Below are the video formats that are supported by Lumia 900. m4a, .m4b, .mp3, .wma (Windows Media Audio 9), AAC/AAC+/EAAC+, AMR-NB, AMR-WB. Try the video converter software in order to convert your video files into the above formats.
Thank you.
If your videos are in the right format, you need not change any settings to play that video in HQ.
Maybe the problem is in the extension, as it is not supported by the default media player. You can install another media player from the windows phone store.
You can download VLC media player from here.
Alternatively, you can convert your videos beforehand and then store them in your phone. Use an all video converter to change the format of the video and then store in your device.
You can download a video converter: http://www.any-video-converter.com/products/for_video_free/
Hope this helps!
Drianna allen
Notifications
