HDMI Samsung TV connect to Wifi
Hi Bro,
I have a Samsung LCD which has a HDMI post and i need a way to connect it to my Wifi so i can use my iPhone to control the TV
Any ideas on steps to achieve this?
Thanks
Hi Bro,
Thanks
There are several ways to connect Samsung LCD/LED to wireless networks depending on the model and specifications of your LCD/LED. If you have bought Samsung model with a built-in WiFi, it would be simple to connect:
Confirm your LCD supports wireless networking.
Go to Television’s Setting Menu > Find Wireless Networking Setup option > List of available Access Points > Select your Wireless Connection > Enter your Network Password >Wireless Setup is complete.
HDMI port is used to connect your LCD/LED to another TV like Apple TV or iPhone or any other compatible device. If you have connected your LCD/LED to a device, again you have to follow the above steps to get connected to your wireless network using password and IP address.
