Headphone Or Earphone
Which would be a better thing to buy when it comes to streaming music? Is it the headphones or the earphones?
Deciding between headphone and earphone is very tough.
• If you are on a lower budget, then earphone is the way to go.
• If you want to buy a lower budget headphone, you should take note that most of the budget headphones are uncomfortable to wear for a longer duration.
• If you want to wear it for the gym or want to wear while jogging then nothing is better than some good pair of earphones.
• If you produce music, then go for headphones.
If you are still confused then remember this, headphones are uncomfortable for a longer duration than earphones. But if you use earphone for a longer time, then you might damage your ear.
