Hi there,
How do I play games on my laptop (HP Pavilion SleekBook) without it going off after every 30 minutes or so into the game? The computer gets really hot and am suspecting the heat sink or thermal contact has a problem, how do I change my laptop's heat sink and thermal contact?
Heat problem on HP Pavilion SleekBook
First of all, there are two solutions to this:
Open the laptop cover from the base, locate the fan, heat sink, etc. and clean them manually
Buy a new laptop cooling pad
To clean the laptop manually, follow the steps below, but this can cause your warranty to become null and void:
Turn over your laptop so that the bottom side is towards you
Irrespective of your laptop model, there will be a set of screws holding the fan to the laptop. Take off all the screws and the cover
Most probably, you will find two fans inside
Clean them with an ear bud or a small piece of cloth
If you want to delve further, unscrew the fans from the hinges and take them out
You will find the heat sink inside. Clean it in a similar manner
If you now unscrew the heat sink, you will find the CPU
Make sure your hands are free of any static charges, otherwise use an anti-static band
Take out the CPU. You will find old rusty thermal paste
Clean it properly before using thermal paste on it again
Take thermal paste and smear evenly on the CPU contacts, both on the board and on the CPU
Replace the CPU, heat sink and then the fans
Make sure all contacts are screwed tight
Replace the back cover
