baitan
Posted on - 10/31/2011
Hi Experts ,
I am a fan of 3D graphic monetization. Could you please give a suggestion on what would be the best software that I can use? I am really new with this so please help me out and if have a website that could offer a good tutorial let me know also. Thanks!
Help with 3D graphics Please !
There are many software that you can use to create 3D graphics but it is not a single software only but rather you need many software. I suggest that you buy this software.
Autodesk 3D Max – Good software for creating 3D models and has a limited amount of 3D animation
Autodesk Maya – Good for modeling as well but mostly built for animation. Max files can be imported to this software.
Adobe PhotoShop – If you are into interior designing, PhotoShop can fix some of the details in your 3D rendered file.
Pinnacle Studio – It is easy to use video editing tool, good for mixing your 3D videos or effects.
Vary – It is a good rendering software available for Max, Maya and Photoshop. Removes any unnecessary lines.
I hope that this software helps you in creating 3D effects. Visit www.tutorialized.com for tutorials of this software, they will give you good samples and also use the help function of each software to learn the step-by-step way to use the software.
