To play Wii and Nitendo video games we use an emulateur: dolphin. I want to know how we can dolphin install patch 3D Vision (version 2). Even after downloading the patch file and compiling it, It makes no change.
Many thanks.
Help about dolphin install patch
To solve this problem, at first check your patch code that is correctly downloaded.
If there is ok, now you uninstall the previous ” Wii “and” Nitendo” video games from your PC. Now again install the” Wii “and” Nitendo” video games and patches code on your PC. Always mind it install the patch code before play” Wii “and” Nitendo” video games.
Hello there Calistamadisonn,
I would like to recommend you to switch to the most recent version of dolphin emulator. Select the type of your OS you use.
http://www.dolphin-emulator.com/download.html
General Configuration.
Once you have done these steps, then reinstall the games and the patch file.this should make changes. Hope that will work for you.
