Help about image batch processing please
Hi experts,
I have an endless number of images; to resize, convert, etc. Do you think image batch processing is a helpful solution to make it easy for me?
Thank you
Hi experts,
Thank you
Although I haven’t done it yet with images, batch processing on images or pictures will really help you shorten the length of the process of converting or resizing different pictures. All processes are done automatically besides the fact that this procedure will also result to some errors and this is inevitable.
Just properly configure the batch process to get the right result then just monitor for any possible errors that might occur while the whole processes are happening. The accuracy of the whole process also depends on the software you’ll be using. Adobe Photoshop is one reliable application and also supports batch processing of images.
