sumons
Posted on - 10/28/2011
I have a Nokia 5310-c music express mobile. For internet browsing I want to use mozilla-firefox or other good browsers. Can I use these kinds of browsers in my mobile or if there is any browser that is best suited for this mobile. Please help me.
Jackman
Help about internet browsers in my mobile Nokia-5310c.
The mobile browser that I may recommend for you is UCweb browser by Java J2ME. It is an inbuilt features that can support audios so you can listen to some recorded clips, video you can take them and view or watch them using your mobile and multimedia more player which is an additional feature. It can also push SMS. It also helps in saving of off-line contents therefore you do not easily loose data or messages from your phone and it has a multimedia download thread which will ensure easy downloading and even uploading of contents. This could help you because it is easy to download and use.
lee hung
75 points
Hi Sumon,
I do not think you can use Mozilla Firefox or Google chrome or other popular web browsers for your mobile phone, but there are those browsers that have been specifically designed to be used for the mobile phones. You Nokia 5310 will work pretty well with the opera mini browser which is mostly used for mobile phones because it is light, fast and the latest version that I have seen being used supports tabbed browsing while being used on the mobile phone.
Firefox and the other browsers are large and heavy and so they are designed to be use on PCs, unless there are special versions or mobile applications of the same that have been designed.
You can download opera mini on your phone from the ovistore, or from getjar on your phone.
__
Regards
Lee Hung
If you want to install Mozilla Firefox on your phone, unfortunately, you cannot because you have a Java phone and Mozilla Firefox is not available on Java phones. If you want to install a different web browser on your phone as alternative to the built-in browser of your phone, you may try UC Browser and Opera mini. Opera mini is available in Java version as well UC Browser.
To download the latest UC Browser for your Java phone, head down to UC Browser Homepage and download the Java version. To download the latest Opera mini for Java phones, go to Opera Browser All Mobile Applications.
