Help about latex proposal download
Hi guys,
My homework is about latex. I only know that is a kind of language for writing documents. I need to find down more about latex proposal. Please tell me where I can take a latex proposal download and how to use it in details.
Answered By 0 points N/A #178873
Hi Tia Heyen,
Latex is a macro package that is used to add a document markup language to gain basic TEX facilities.
It was written in early 1980’s.
You can download it from the internet easily by searching "NSF Latex Proposal"
It is used to create new and improved documentation user interface for designer is promised.
It is a template which is used to design documentation proposals.
This template uses the TIME FONT, which converts easily to PDF.
It supports complete bibliography which is located in “draft.bib” file.
You should need to know two special style files of Latex.
One is”proposalnsf. cls”, which is a proposed class file for Latex, it is originally developed and updated in June 1/2008.
The second is an older version named “proposal. cls”, “jponew.bst” is a bibliography file which is based on AMS bibliography style file.
It was infiltrated from the bibliography style file of AGU.
These are the brief and important points of the Latex Macro package.
I hope you’ll know more about latex and its use for making proposal documents. Good Luck!
Johnstoon Leen
