Help about powerpoint effect flip
Hello Guys,
For our company purpose I am in need of preparing a PowerPoint
presentation. I do know some basic controls of PowerPoint. But I am a little bit confused about the PowerPoint effect flip. So please answer here with an example. So I really can understand it. Thanks
Answered By 70 points N/A #176449
Hi, Grant.
You can do one example very easily. You will need two pictures of the same size that can represent two sides of one same object. For example, two sides of Earth (back and front). Put this two pictures on one, same slide and add animation effects to each of them in order to make them move the right way.
Apply  the following effects: Object 1 – Collapse exit effect – on click; Object 2 – Stretch entrance effect – after previous; Object 2 – Collapse exit effect – on click; Object 1 – Stretch entrance effect – after previous. Now, set all four effects to run at equal speed to make the picture flip smoothly. Position the front picture on top of the back one. Now, preview your slide to make sure the picture flips over the right way. That's it. Now you have seen this simple effect. You can save your presentation if you want or make some other example.
On the following you can see this example in practice: https://www.ispringsolutions.com/blog/how-to-build-a-custom-flip-animation-effect-in-powerpoint-for-your-website/
Don't be scarred to try different effects, it's fun and nothing serious can happen. Just be careful to save your presentation before you experiment with new effects.
Regards.
