Help about QuickBooks pro hotel management please
Please indicate the main steps I should follow before downloading quickbooks pro hotel management to avoid any program conflicts ?
Thank you
Thank you
Hello Debra,
The first obvious step would be to determine what OS your computer is running on so that you can download a version of QuickBooks which is compatible with your operating system. After determining your OS you should ensure that the version of QuickBooks you are downloading conforms to your computer’s specifications. These are the basic steps; since you did not mention what OS you are using; follow the link https://community.intuit.com/articles/1501893 to obtain a step by step procedure for installing QuickBooks. I hope this helps.
