Help about thesis proposal is needed?
PowerPoint is a very powerful tool for making presentations. It is certainly the best for this type of area because you can do a lot of things like using graphs and a lot more. But if you will not use it, there are lots of alternatives. One way is to use flash. It is used for animation. It is certainly better than PowerPoint presentation but it takes a lot of effort. But if I were you, I prefer to stick to the easiest way where I can handle well.
Greetings,
There are four best alternative solutions for Microsoft PowerPoint those I know are:
1. Prezi (https://prezi.com/)
2. Brainshark (https://www.brainshark.com/)
3. Slide Rocket (www.sliderocket.com)
4. Google Docs
If you are not interested to use PowerPoint (even PowerPoint is best & easy solution to create presentation slides), then you can use anyone of above.
