Hi people. I have a Galaxy Notepad 10.1which has the Exynos 4 Quad chipset. I can't find an alternative free calculator app galaxy pad on Android Market. I'm looking for a calculator with currency converter and tip calculator in one app. Any leads? Thanks
Help in alternative free calculator app galaxy pad
Hello there Jonathan,Â
There are apps available on Google play which is either calculator or a currency converter. But this combination of functions app doesn't seem to be available yet.
So for now you can just install XE Converter app.
And have your pen ready or just copy the result and paste in your calculator.
Hope this helps.
Waall Mike
Hello Jonathon,
There are a lot of applications in the Market that can do what you need, but it is hard to find one that does all of them. With some research I have found a great calculator which has all of the features you need in one. The Application's name is "Financial Calculators" and you can find it at the following link: Financial Calculators
This application has a built in currency converter and tip calculator, on top of the TVM calculator, so it is everything you will ever need.
P Vhilary
Hi Jonathon,
There's an available application in the Android market that bears those features. The application's name is Calculations 4.0 Free by White Gorilla Media, Inc. It serves as a calculator, currency converter, unit converter, mortgage calculator and tip calculator all in one. The free version comes with advertisements and have limited function.Â
Hope this helps.
