Help the application was unable to start correctly
Hi.
I have received an error message when I try to start the Tr-Zero_R1.exe application saying “The application was unable to start correctly”. There should be solution to fix this bug. Looking forward your instructions. Thank you!
Tr-Zero_R1.exe – Application Error
The application was unable to start correctly (0xc0150002). Click OK to close the application.
