Help with bd player for Windows 7 64bit?
I have Windows 7 Ultimate 64 bit installed, and today I was trying to play a Blue Ray Disc but Windows Media Player won’t play it.
Does anybody know how any 3rd part bd player for Windows 7 64bit?
Hallo Nimrod,
If a Windows Media Player cannot be able to play the files on the BluRay Disc, it is because they are not in a format that is not supported, or it could be possible that the Windows Media Player Codecs are out of date.
To resolve the issue you will need to do the following:
Solution 1:
You will need to update the Windows Media Player Codecs as follows:
Solution 2:
You can as well use an alternative media player application.
Carl
Notifications
