Help on booking calendar source code html
Hi guys,
I am looking to develop a booking calendar website, the problem is my current code seems not to be working the way I want it to, what i would like is a commented booking calendar source code html sample or direct me
to a website that provides such samples that I can review for help on my problem.
I will use this sample to incorporate as many features as possible into my work
If anyone can help me on this please reply to this post.
Answered By 5 points N/A #136105
Hello Avah
Are you sure that you wrote the code as you were supposed to? A debugger may also be a solution in order for your code to work.
However, after doing a little research, I can provide you some sources that I am sure will be of great help in fixing your problem.
You can find many Booking Calendar source codes, but they vary a lot. It's all about the user's requirements. So it's better that you choose the one that suits yours.
You can chose from this list a various numbers of Booking Calendar sources. Booking Calendars
I hope you will find this information useful.
Randolph
