edcasey
Posted on - 03/16/2012
I want to change my laptop's keyboard because the "A" key just popped up. I want to change it by myself because I bought the key from online shop. So here I need some tips. My laptop model is HP Compaq cq-42.Â
Thanks
Help Change HP Compaq Keyboard
Hi Edcasey,
It is not that easy just to take out a key from laptop and replacing it with another one. It is a very hard process and any way I have included the tutorials available on the internet for doing this process in step by step procedure. Try to do it with extreme care without losing or destroying any microscopic parts available on the laptop internals. The following tutorials are made for another laptop but all the laptop model comes with universal keyboard architecture and you can simply follow it without having any difficulties.
The first tutorials is : https://www.wikihow.com/Pop-a-Key-Back-Onto-a-Dell-Laptop-Keyboard and the next one is : https://www.laptopmd.com/2010/07/26/replacing-keyboard-key-on-your-own/.
Try to do the process with great care and hope you fix your problem 🙂
