Nina Marie
Posted on - 03/25/2012
I don't know much about cloud computing and I think that's why I encountered this problem 🙂
I Have finished the server-node installation and after that connectivity.
I'm able to access the interface by using Https://<cloud-controller's IP address>:8443.
But it gives me error, "[ERRNO 113]no route to host " when I try to run the commands euca-authorize default -P tcp -p 22 -s 0.0.0.0/0.
Help with cloud computing in Ubuntu
I think, your problem occurred when installing cloud into your Ubuntu server. However here I give you a detail process to install cloud in Ubuntu. That may be a perfect solution for you. For doing this you have to use Ubuntu enterprise cloud. It’s a system, made up specially for one controller and one more node controller.
At first I’m going to discuss about the requirement for the installation.
You must be use at least two computers to create cloud installation.
For the cluster controller, you need a 512MB of memory of 1GHz CPU, 40GB of disk space, CD-ROM and an Ethernet network adapter.
You need one another node controller(s). It must have the capability of CD-ROM, 1GB of memory, an Ethernet network adapter, and a 40GB of disk space. Also the CPU have to support with Virtualization Technology extension.
The whole process you will find this site
You can visit this site also for a another way
And Ubuntu com cloud
