Help in configuring Tune up utilities
I'm having hard times configuring and setting my tune up utilities,
Please help me how this works.
And what will happen if i turn on the turbo mode?
You did not say what tune up utility application you are using. There are lots of tune up utility applications out there and each and every one of them has different options and abilities and the only similarities they have is that they are made to improve and speed up the processing of the computer.
Here is an example of a tune up utility application. I have PC Tools Performance Toolkit 2011 on my computer.
This application optimizes the system and improves the system performance.
The Clean your Registry option will clean your Windows registry from registry entries that were left by previous uninstallation of applications. When you are uninstalling an application on your computer, not all of its registry entries in the Windows registry are removed. Most of the time there are leftovers.
The Defragment your Registry option will analyze first your Windows registry and then compact it to remove the gaps between different registry entries.
