Help convert ldap to xml URGENT!
Hi there,
My boss has tasked me to convert many our ldap users to xml, but the problem is I can't seem to find a viable source. I asked my boss to consider DSML as there are plenty of tools (both open source and proprietary) of that.
I have searched high and low but was not able to find a good enough tools. Can anyone of you techie's please recommend me a good software to convert ldap to xml
Please I really need your help.
Thank you.
Best Answer by Bennie S Easter
Answered By 20 points N/A #191823
Hello Green Scott
There is a tool which will allow you to convert the ldap to XML. Since this OpenLdap/Novell LDAP class library is required on the system. This tool has been tested on JDK 1.2, 1.3.1 and 1.4.2
You can download this tool from here LDAP to XML
It is an open source tool and for further information regarding this , you can refer to this link  http://thewalter.net/stef/code/ldapxml/
Hope this will help,
Thanks
Bennie
Answered By 0 points N/A #191824
Hello Green Scott
This tool will achieve your goal to convert lpad into xml
You can download by clicking on the following link.
Binary JAR: ldapxml-0.9.4.jar
Full Sources: ldapxml-0.9.4-src. jar
So that when you set up this tool , you will be able to restructuring lpad users into xml
