HI guys,
I am looking a rich text to jpeg format, I need the
document in jpeg form for emailing, what I would like is a good software
solution that I can use to achieve this with the best possible quality of
output. The software should preferably be available for free.
If anyone can help me on this please reply to this post.
Help on converting rich text to jpeg
Hi Bolton,
I listed below some of the recommendable free software that will aid you in converting files.
Rtf Tiff to Jpg Jpeg Converter 3000 – This free software will assure you that upon converting your rich text file to Jpeg, the highest quality will still embed to it.
RTF to Image Converter – They offer an evaluation copy that will give the user the opportunity to convert several RTF files into a desired image format.
Okdo Gif Tif Rtf to Jpeg Converter – This utility tool allows user to convert several file formats such as RTF, GIF and TIF to wanted layout. The best thing about this software is you can convert multiple images at one instance. That's very efficient thus will increase your productivity.
Hope you doing fine. There is a number of ways that you can convert rtf to jpg. But you will have to download an application that will convert your files
First, you will have to download RTF Converter. Then install the application and open it.
Open the file that you want to convert.
Click on the Convert option and choose Convert to JPG.
Choose where you want to save the new JPG file
