I am using DLink camera model -DCS-930L Wireless Network Camera. It works well on Windows XP, but not in Windows 7. It seems that I must install dlink camera active x for windows 7. If yes, can you please help me how to download, install and configuration it?
Help with dlink camera active x for Windows 7
Hi Joby Mathias,
The Dlink camera installation wizard itself provides the link to download the activeX. However you may face trouble installing it directly. So before installing go to control panel and select the internet options.
Once the internet options wizard pops up go to the security tab and click on custom level. Scroll down to the activeX section and enable the activeX options required.
Now install the activeX file. It should work fine.
Powel JEdei
