Help drupal news rotator problem
I have been a member of Drupal for a long time now.
I have been using the image rotator things and all, but now I want to use the news rotator thing, and it just doesn't function.
Any help with that?
Any help with that?
Drupal is a free application that allows you to easily manage, organize, and publish your content and has an infinite customization variation. It is an open-source application that is developed and maintained by a community of 630,000+ developers and users. If you think your program is not functioning correctly, try downloading the latest version from Drupalâ„¢ | Come for the software, stay for the community to upgrade your present version.
If you don’t want to download the latest version and upgrade your software, you may try doing a clean installation of the program to fix any corrupted files that may be affecting the application. Uninstall Drupal then restart your machine when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. Install the software again then see if this fixes the problem.
