Beatricez
Posted on - 07/22/2011
Willing to share case on my laptop when right click a file, copy or even when going to delete windows installer always comes up and directly setup process goes . Setup is running always bring up the "Adobe Acrobat installer".
I've tried to uninstall Adobe Acrobat and his success, but when the restart is still the same.
I've tried to virus scan using NOD32 (update 18-04-11) and smadav8. 4 and still same results.
Rekan2 is anyone aware whether this is a virus, Malware or the like?
And how to overcome it because even if ultimately we can copy, or delete a file is still severely hampered when we use a laptop.
Windows Installer appears when right-clicking
This is the sign you should look for on the task bar right corner. This is an icon for Acrobat update and does not get un-installed when it is running. It starts with the start up activity of the machine. So it appears even when you un-install Acrobat.
Right click on the icon and disable it as shown in the figure.
This will switch it off for the session.
Go to Start > Programs > Startup > Camera and Card reader.
Then uncheck both options shown in figure.
Un-checking the auto launch option will solve your problem.
I wanted to thank you for this informative analysis of the subject.. Thanks again Ian Richardson
