Help to find a dictionary of Singapore English Style Guide
I am not sure I put the correct keywords to find a dictionary software of Singapore English Style Guide. Do you any suggestion for me?
Thanks,
Thanks,
Hi! Tomson,
You have a problem is about the dictionary software of Singaporean English.
I suggest you must download the Singapore English Dictionary from this link
This is can help you to encode correctly and the grammar correctly by using that software.
When you are not sure of your Singaporean English you can use your dialect and then translate it what you want language you want to use.
Just use this link to translate your work https://translate.google.com/
Just copy and paste then the translated word at the right side of the screen.
I hope that somehow I had good suggestion on your question .
