Hi friends, In office . I need to work with google docs. Â Always, I am accessing google docs strikethrough from menu. Even in demanding situation under pressure. Is there any other way to access google docs strikethrough or perhaps a way to add the strikethrough command to the tool bar. Please help me . Â Thanks
Help in finding solution to Google docs strikethrough command
Hi Kurtt Stewart,
There is good news for you and all the Google fan out there. Now you do not need to access it from the menu. Google finally address the issue and give its user a shortcut key for strikethrough.Â
You just need to Alt + Shift +5 to access strikehrough.
You can have a list of shortcuts for using with Google Docs here which was published by Google themselves.
Thanks & Regards,
DBD
