Help With Helvetica Neue Free Download.
Hello everyone,
I need help with Helvetica Neue free download. I would also like to understand the procedure to install it in MS Word 2007.
Hello everyone,
You can follow the steps to install Helvetica Neue font on MS Word 2007
1) Download the font from any website, for e.g.
2) Extract the ZIP file to a new folder.
3) The font files are in two formats, TTF (True Type Format) and OTF (Open Type Format)
4) Now open the folder that contains the fonts.
5) Open control panel and on the “View By” options, select large icons or small icons but not categories.
6) After this open the “Fonts” folder.
7) Now select all the font files that you download and drag them to the “Fonts” folder
8) This will start the installation of the Helvetica Neue font, and now they are ready to be used.
9) Open MS Word and you can select Helvetica Neue font
