Problem in connection after installing VM Ware
First I encountered a problem  with my adapter setting, I installed VMware and have a problem with connection.
Can anyone help me?
Thanks in advance.
Can anyone help me?
Thanks in advance.
Ok John_brain22, Â
Try to check your internet adapter first, disable your VMware network adapter and try to enable your default Windows network adapter.
Yes John,
I have the same problem like you. Â
Try to search in Google, because I think last year I had this kind of problem and I know that duplicate connection will be lost?
I think this is because double connection or duplication, happens.
IÂ hope it helps you in a simple way.
Try to reinstall your network adapter with your VMware or disable one and choose your default Windows network adapter. Please don't forget to do that again.
If your problem is solved, try to bookmark it so  you do not forget it.
I think this helps you.
God bless.
