Help! I can’t restore Files
Hi! I have a problem with restoring files. The problem is that the to ‘OK’ button is not embedding. Even though finding the file is no problem restoration is impossible and I have no choice but to copy paste. I am not able to find any diagnosis of the problem either in the desktop wizard or with windows. Your help is highly welcome.
Answered By 0 points N/A #116305
That may be a temporary problem that is occurring due to the application freezing or just malfunctioning, or in the worst case the application may be corrupt. I will suggest that you try the following workaround:
  • Close the application.
  • After that open the task manager and under the processes tab close all the processes that are being executed by the application.
  • And then restart your computer, and thereafter restart the application.
  • Try restoring the files once again and see the response.
But if it happens that the application is corrupt, then the remedy will be to uninstall it and then do a fresh installation of it.
-Lee Seen
