Help importing acad into file that vue software can handle
I work for a landscape Design Company where we use AutoCAD for landscape projects to make contours and landscape designs. I recently started to use VUE software instead and I need to start importing acad into vue. Unfortunately, I tried importing file formats like ".3ds" many times but VUE couldn't manipulate. My question is what is the appropriate file format available in AutoCAD that can be imported and fitted to use in VUE?
