Help with install RDP on my N9.
I need to install RDP (remote desktop) on my N9 phone, because I have to connect to my Mac. Anyone knows of any apps that supports that?
Hello Isabellagregorey,
In N9 The OS is MeeGo and you can try Meshcentral – Remote MeeGo Desktop for your device. it has a simple requirement before installation. that you have to root your device first which may void your warranty. you can try Meshcentral.com it can help you for setup steps of the software.
Thanks & hope you can resolve it.
I will tell you, how the Remote Desktop Mobile client on N9 works with MAC or Windows OS. You need to follow 3 easy steps.
1. Set up your system to enable remote desktop access.
2. Download, install remote desktop and remote desktop client on your Nokia N9.
3. You need to enter the IP address of your desktop in “Remote Desktop Protocol server”. For username you have to use your System login and password field and leave others as default configuration.
4. Then “Connect”.
