I would like to ask for your proper guidance about this. How can I install Kitkat in my phone? What are the system requirements for this? Will my phone work with Kitkat? What are the benefits of installing and using this? Can you show me how to do this step-by-step? Do I need to save the applications or programs first before I do this? Do I need to download additional add-ins so that I can make it work properly? Thank you very much and have a nice day!
Help in installing Kitkat in Android phone galaxy S4
The Samsung Galaxy s 4 is surely capable of running kitkat, Kitkat isn't officially realesed for Samsung Galaxy s4, But you can still install via custom roms, The best custom rom out there is cyanogen mod, Cyanogen mod offersis more beatiful and lighter than touchwiz, You will also get all of the amazing features of cyanogen mod such as UI button configuration, And privacy guard, You can easily install cyanogen mod by downloading cyanogen mod on your phone  here, But before you do this, You need to enable unknown sources by going to Apps > Settings > More, And check unknown sources, you then need to install the app and from here you can follow the steps provided by app to install cyanogen mod
