Help in installing Oracle 10G on Windows 7
Dudes,
I am looking for help to install Oracle 10 G on Windows 7. I have downloaded the 10.2.0.3 version but I cannot install it because an error is occurring.
‘Checking operating system requirements.
Expected result is one from 5.0, 5.1, 5.2, 6.0. Actual Result is 6.1.
Checking completed.
So the result is failed.
Oracle database 10 G does not have certificate on this OS. Recommendation – Please confirm you are installing the application on the correct platform. Service pack checking result is not executed.
Windows Vista V 6.1 is not supported. Please install the recommended service pack. Physical memory expectation is 256 MB and result was 1406 MB. So that checking was passed. Network configuration checking failed. Problem found that the IP of the computer is assigned is DHCP.
Oracle supports installation on computers with DHCP assigned IP, but you should configure the MS Loopback adapter as the primary network adapter in the computer.
See installation guides for more details regarding the installation of software on DHCP configured computer. '
I have installed the MS Loopback adapter, but is  no change in the results. Please give me some inputs. I will be grateful for all the help.
Thanks in advance.
