Help “Internet Explorer Script Error”
Asked By 400 points N/A Posted on -
I need help guys.
Every time I enter and start surfing the internet, I always get this kind of error. I don't know what to do and what kind of error is this. Please help me to fix this error.
Is it the sign that my PC has a virus?
Thank you.
An error has occurred in the script on this page.
Line: 10
Char: 1
Error: 'jQuery' is undefined
Code: 0
URL: http://my.freecause.com/js//jquery.cycle.js
Do you want to continue running scripts on this page?
Best Answer by jeffr
Answered By 0 points N/A #112979
I am giving some Methods. You can try them one by one.
Method 1: Disable script debugging
If the only sign of a problem is the error message, and Websites are working, you can probably ignore the error. Also, if the problem only happens on one or two Web pages, it might be a problem with those pages. If you decide to ignore the errors, you can disable script debugging. To turn off the Scripting Debugger in Internet Explorer 6, follow these steps:
1. On the Tools menu, click Internet Options.
2. On the Advanced tab, click to select the Disable script debugging check box. And then click OK.
Method 2: Test a Web page from another user account, another browser, and another computer.
Use another user account, another browser, or another computer to view the Web pages that triggered a script error to determine whether the problem persists. If the script error persists, there may be a problem with the way the Web page is written.
Method 3: Verify that Active Scripting, ActiveX, and Java are not being blocked by Internet Explorer.
Active scripting, ActiveX, and Java are all involved in shaping the way information displays on a Web page. If these are blocked on your computer, it may disrupt the display of the Web page. Reset the Internet Explorer security settings to make sure these are not blocked. To do this, follow these steps:
1. Start Internet Explorer.
2. On the Tools menu, click Internet Options.
3. In the Internet Options dialog box, click the Security tab.
4. Click Default Level.
5. Click OK.
Note 1) ActiveX controls and Java programs are turned off at.
Answered By 5 points N/A #112980
Above comment shows you some methods to solve this problem. It shows you very well how to solve this. Also the above solution applies to Internet Explorer 6, 7, 8, and 9. But if you still couldn’t solve the problem I can give you a solution.
Please update Internet Explorer to the latest version. You can update this from Windows update. Please follow the steps to update your Internet Explorer.
1. Open the Internet Explorer then press ALT and T together.
2. Click Windows Update.
Also you have to update your Operating System. Then check your problem again. If you will not able to solve you can use Microsoft Fix it tool. This tool can solve your problem. I will give you a link to use this tool.
If you need more information about this problem please go to the below link.
Hope this can solve your problem.
Answered By 0 points N/A #195636
Hi Bheeelaat,
Your problem is interesting. I think it can be solved.
At first I will suggest you to use Google Chrome or Mozilla Firefox.
In the matter of IE,
Remove you all caches and cookies and open it again.
It should work. If not then make sure that JavaScript setting is correct.
Set the default level on security option. Let know what happens? Is it done or not?
Thanks
Mothy Stewartyi.
