Help in Loading Libraries From Shared Libraries
Hi, I am a Mac user; I frequently use my private library, and I link it often.
You cannot use the private path to access the libraries. All you can do is to find a way to make these files secure since you might not want anyone else to use them or to listen to what you are listening.
For this you need to download a library manager that would create a password for every library you have. You can even arrange your library according to different categories from that software.
So instead of using the iTunes or any other software, use the library manager as it will give you the access to use your library in a lot more simpler and easy way of handling it.
