How is the battery life of Fugoo Tough?
How many speakers are available in this? Can I hear 360 degree sound from this?
Which metals are used to develop Fugoo Tough Bluetooth speaker?
Can you explain Fugoo Tough Bluetooth speaker audio quality?
How many ports are there?
Describe the power and environment of Fugoo Tough Bluetooth speaker.
Is there any USB Cable and Audio Cable available?
Help me about Fugoo Tough Bluetooth speaker
Happy to support you!
The Fugoo Tough Bluetooth speaker has many outstanding features like,
the long battery stand by duration of usually up to 40 hours (with continuous use with 50% speakers)
speakers on all the sides & corners, facilitating a 360 degrees sound spread
fiber-reinforced resin & a solid aluminum casing
95 dB sound pressure level
with a micro USB cable & a full duplex audio cable
More information
Hello Aditya!
This is a multimedia device or system that I will never miss to have.
Here are the best ever features of this one of a kind speaker.
1. Battery Life. Expect that one (1) day and a half or roughly 40 hours continuous playable music without interruption or reception issues in sound quality until it drains the battery.
2. This speaker comes in with one set of multiple speakers. It’ll compose of 2 tweeters, 2 woofers and 2 passive radiators. The speakers are organized 8 degree upwards so you can hear the sound perfectly. It will automatically change/adjusts the bass, mid-range, tweets as we changes the volume level. It’s like an intelligent equalizer. So it will definitely preserves the audio quality of any sound files.
3. 360 Degree Sound feedback. It will provide you the sound quality and consistency no matter what angle you move on to if you’re facing the speaker left, right, quarter side, and any side will not make any difference it is a total Hi-Fi class of speaker. You can also use SIRI or Google Now to play music. The sealed production of this speaker makes the sound even better.
4. All Terrain Speaker. You can throw it, drop it and sink it in mud, snow or water, or mix it with pebbles or stones without thinking that you just put your money in to waste. We can make sure that this speaker will still give as quality sound feedbacks even the depth of 1-meter under water.
5. Created with neodymium magnet that serves protection for the speakers and at as a heat sink. Hollow cylinder that provides suppression on the sound/acoustic resonance.
6. We can use Bluetooth connection that can extend up to 33 Feet. Micro USB for charging, updates and downloads.
