Help me about Server and application monitor SAM v6.2
To install SAM following things to be considered.
1. Hard Drive 4 GB
2. Memory 4 GB
3. CPU 2.4 GHz at least
4. .NET Framework 3.5 & 4.0
5. OS should be Microsoft IIS 6.5 & higher version also 32 bit. The Windows server 2003 R2, 2008 R2, 2012, 2012 R2.
6. Database should be SQL.
7. Web browser should be Internet Explorer 8 and higher version, Firefox 35 and higher version, Google Chrome 39 and higher version.
To create reports using SQL query you have to click start -> All Programs -> Reporting -> Report Writer. Click New Report -> Historical – VMware ESX Reports -> OK
Enter the title and enter the query “SELECT VIM_VirtualMachines.Name as ‘Guest’, VIM_Hosts.HostName as ‘ESX Host’ FROM VIM_VirtualMachines
Inner join VIM_Hosts on VIM_VirtualMachines.Hostid=VIM_Hosts.HostID
where VIM_VirtualMachines.NodeID is null.” in the description space and execute it. To run its required .NET framework.
