Help me with assembly language for color code.
I want to write a code in assembly language for color code that will put 32bit color on screen. Does anybody know the code for this? Any kind of help would be appreciated.
Hi Jabez,
Assembly code is a program language that can be used directly to tell the computer what to do. It's like a machine language that a computer can understand it. except it uses a words in place of numbers. Assembly language also allows programmers to write the actual data that uses in easier ways. Also it provides abstraction of machine codes. Here is the website that help you to get some codes for language codes http://freedownloadsapps.com/s/assembly-language-color-codes/ . Happy downloading.
Sara
